Brief Description: Applied Cotter Pins to Right Rudder Cable Screws
The two screws holding the linkage between the right pedal and the rudder cable were removed. A spacer was already installed on the pedal screw, but it was too long. The spacer was ground down a little. The spacer was reinstalled on the screw and the linkage was put back on the screw. The castle nut and a thin washer was tightened on the screw, along with a cotter pin. The cable screw had a spacer installed on it. The screw was tightened and the cotter pin installed.
The left pedal screw has a cotter pin already installed. The left cable screw had its nut unscrewed. A spacer and a cotter pin needs to be installed.
Torque seal was applied to the nuts on the fuel tank support brackets.
The right rudder pedal screws with cotter pins installed
Torque seal applied to the nuts on the fuel tank support bracket
