Brief Description: Nav Light Power Wires in Fuselage
The nav and strobe wires in the black looms that come into the cockpit were tie-wrapped to the inboard rib on each side. The right nav light power wire was labeled and run from the right side of the cockpit thru the seat ribs to the left side. The two nav light power wires will be connected under the seat and then one wire will be run up along the left side of the fuselage, connecting into the P-1.
