Brief Description: Installed Screw on Fuel Tank/Fuse Bracket
With Walt's assistance, the bottom hole below the fuel tank/fuselage bracket was countersunk and then a washer and nut were installed and properly torqued with the screw. The screws go thru the internal reinforcing bracket on each side.
The fuel tank/fuselage attach bracket fully assembled
