Baker's RV-6
RV-6
Drilled Wing Tip Rib to Wing Tip
The rib was inserted into the right wing tip and clamped in position. The tip was marked for the rivet holes with appropriate spacing and then the tip and rib were drilled together.
The lower side of the wing tip
The top side of the wing tip after drilling
RV-6 Home
5540
544
Control Systems
Cowling
164
199
666
124
570
Flight Training
1225
Inspection
Instrument Panel
142
227
256
Shop Construction
Systems
Weighing
1334
Wiring
126
216
