Baker's RV-6
Date:  9-28-2012
Number of Hours:  0.50
Brief Description:  Began to Run Wire for Hobbs Oil Pressure Switch
One of the firewall penetration kits was loosened up, so that a wire could be added thru the center. This wire will run from the Hobbs oil pressure switch on the firewall to the P-1 connector to provide input to the Low Oil Pressure light on the instrument panel. The wire is 18 gauge and yellow. A wire spoon was inserted to get the wire into the bundle, but the wire has not gone all the way thru yet.
The wire spoon and yellow wire
