Brief Description: Pulled Elec Ignition SloBlo Fuse Wire Off
The slo-blow fuse for the electronic ignition going to the battery was crimped to the wire going from the electronic ignition circuit breaker to the battery. The crimp was actually a wire with a heated crimp that did not properly melt onto the slo-blow fuse wire. The slo-blow fuse wire was able to be pulled out of the crimp. The wire was reinserted into the crimp and the crimp would not release any more solder into it to grab the wire.
The slo-blow fuse holder pulled out of the solder crimp
