Brief Description: Drilled Trim Cable Hole in Center Fuselage
I had forgotten to insert the trim cable into one of the two holes in the center section of the fuselage while running wires. There is no more room in the holes for the large cable, so another hole had to be drilled. A 5/8'' hole was drilled to the right of the rib from the center. The cable will be routed thru the hole in the rib into the center of the fuselage and an Adel clamp will be used to keep the cable in position.
