Brief Description: Found Amp Wires too Short/Pulled out Dynon
As Fred and I were getting ready to rivet the right side of the top skin, I tried to pull the Dynon EMS out of the panel for easier access to the subpanel. I could only get the EMS less than an inch from the panel because of wires not allowing it to come out farther. It turned out that the Hi and Lo Amp wires were cut too short. An extension needs to be added to these two wires.
The Hi and Lo Amps wires are in this mix
The two Dynon boxes pulled out for access to the subpanel for riveting
