Brief Description: Roll Servo Wires/Pinned Mag Wires
The autopilot roll servo wires were laced up and then added to the pitch servo wires along the center of the floor. They were added to the spiral-wrapping. The wires were then run up along the right side center of the firewall and then left with the pitch servo wires. The length of wires was cut to a good length and then pinned with Dsub pins. The wires and pins were inserted into the P15-6 connector, which was joined with the other half of the connector. The bundle of wires was spiral-wrapped with other wires above the left rudder pedals.
The other end of the P-lead for the mag had the shield separated from the conductor. The shield had a wire soldered to it and then pinned with a larger Molex. The conductor was also pinned. Heat shrink was applied and the two wires had white heat shrink applied and then numbered for the pin position in the P1 connector.
The roll servo wires combined with the pitch servo wires on the right
