Brief Description: Made Output Connector for Lightspeed Control Box
After studying the Lightspeed Input and Output drawings and Jason-Aerotronics' drawing, I made the wire and the Output connector for the control box. I used 18 AWG shielded wire. The conductor was pulled out and a wire was soldered onto the shield. Molex pins were crimped onto one end and Dsub pins were crimped onto the other end. The Dsub pins were inserted into a 9-pin connector and the housing was assembled. The connector was inserted into the Output connector of the control box.
The wire is pinned to go between the P1 connector and the control box
