Brief Description: Attached Battery and Master Relay Wire
Jeff Paden came out to the shop and we were talking about the electrical system. Jeff suggested that the battery could be inserted into the electrical system for testing, now that many of the components were getting wired together. I screwed the positive cable onto the battery and also added the Battery Tender Jr. charging leads to both battery poles.
I turned the master switch on, but nothing happened. I inserted the Master Relay wire into the P1 connector and the panel came alive.
