Brief Description: Rotated Smoke System Arm/On Switch
I discovered that the Arm/On switch for the smoke system should not have been flipped. i had misread the directions in doing so earlier. The switch was removed and rotated back to the correct orientation, with the load pole at the top and the 15 on the end of the switch oriented right side-up.
