Brief Description: Smoke System Power/EDC-10A Wiring
The smoke system wire from the pump was run under the left seat. It was pulled up the left sidewall and added to the Adel clamp holding the headset wires.
The wire from the EDC-10A remote magnetometer was stripped in preparation of inserting it into a six circuit connector.
The strobe power wire attached to the bus bar behind the Pitot Heat CB
The strobe power wire coming up along the left sidewall
