Brief Description: Pitch Servo Wiring/Smoke System Power
The wire bundle for the pitch servo had more lacing used to tie up the bundle. The wires had pins crimped and then were inserted into the P15-6 connector. The two connectors for the pitch servo were then connected.
About six feet of 18 AWG wire was run between the smoke system switch and the circuit breaker panel. Ring terminals were crimped on each end and the wire was screwed to the switch. The wire was added to some spiral-wrapping around other wires that run under the instrument subpanel. The wire was then screwed to the bus bar behind the Pitot Heat CB.
The P15-6 connector
The power wire off the smoke system switch
The smoke system power wire attached to the bus bar
