Brief Description: Ran Wires along Center Section/Smoke Wires
The pitch servo wires were tie-wrapped every four to six inches and then laid on the floor. The wires were tie-wrapped to the screw holes along the floor bracket to keep them stabilized for now. The wires were spiral-wrapped and tie-wrapped to the black tubing that goes up along the vertical firewall center bracket. The wires were then run along the firewall top bracket to the left side.
The P7 plug is for the pilot's grip switches. The P7 backshell was removed and the #21 wire was removed. This wire was to be used to activate the Ident feature of the transponder. The wire will be replaced with one from the smoke system. The Ident button on the grip will turn the smoke pump on and off when the Remote Switch is on.
The ground wire from the smoke system Remote Switch was bolted to the instrument subpanel.
