Baker's RV-6
RV-6
Finished Smoke System Tubing
The aluminum tube was attached to the check valve and then thefirewall fitting. The check valve had the rubber tubing inserted and clamped in place.
The tube and check valve
The tube on the firewall
The check valve and tubing
RV-6 Home
5540
544
Control Systems
Cowling
164
199
666
124
570
Flight Training
1225
Inspection
Instrument Panel
142
227
256
Shop Construction
Systems
Weighing
1334
Wiring
126
216
