The tubing for the smoke system was routed along the lower stringer, up the right forward side, and down the angled bracket along the firewall. The fitting thru the firewall came straight out and an aluminum tube of 1/4" had to be made so that the fitting could be joined with the check valve.
The smoke system tube clamped
The aluminum tube attached to the firewall fitting
