Brief Description: Received Slo-Blo Fuse/Soldered Headset Jacks
I had talked with Jason Smith at Aerotronics re the wiring for the power supply to the Lightspeed control box. Jason pointed out that an 18 AWG wire needs to be run straight from the battery to the Elec Ign circuit breaker with a 7 1/2 amp slo-blo fuse inserted between the battery and the breaker. Jason sent a fuse, fuse holder and wire to me, along with an electrical diagram.
The jacks for the phone and mic jacks were removed from the cockpit. Three-wire shielded wire was cut into two lengths for the jacks. One end of each length had the shield separated and the wires were soldered onto a phone jack and a mic jack.
