Brief Description: Applied Heat to Carb Heat Inlet for B-Nut Clearanc
The B-nut hits the carb heat inlet and so Jeff Paden applied heat to that area and applied force against the fiberglass with a punch. After a few times of heating, the fiberglass moved which will allow the B-nut to move properly.
