Brief Description: Carb Heat Control Cable/Ram Air Door Control
The ram air door control movement was marked at the open and closed positions on cardboard. I marked the cardboard for the lowest point on the control arm.
The alternator attach bracket was removed and one air filter bracket tube's hole was drilled up to 5/16" size. The tube was installed on the bolt.
The carb heat cable clamped to the bracket
The ram air door control movement marked
One support bracket screwed to the alternator mounting bracket
