Brief Description: Carb Heat Cable Bracket on Throttle Bracket
I made a triangular-shaped bracket out of 1/8" bracket to which the carb heat control cable could be attached to. The bracket was drilled and then bolted to the throttle bracket in two holes. An Adel clamp was then installed on the cable and bolted to the bracket.
