Baker's RV-6
Date:  1-30-2012
Number of Hours:  3.00
Brief Description:  Installed Carb Air Inlet and Safetied
I received another Aircraft Spruce order, which included four MS20074-04-03 bolts. These bolts were used to install the carb air inlet. The bolts and air inlet were tightened and then safetied on the left and right sides. A section of 3" Scat tubing was cut and clamped onto the carb air inlet.
The carb air inlet on the carb with the Scat tubing
The assembly
The assembly
The left side safetied
