Brief Description: Glassed Carb Heat Deck to Air Inlet
I cut out multiple small pieces of fiberglass and then mixed some epoxy resin. Three layers of glass were applied on each side of the carb heat deck and the air inlet. Smaller pieces of glass were used around the other edges.
