Brief Description: Extended Area on Deck for Handle
The handle was positioned on the ram air door and drilled in position. The cutout in the deck for the handle had to be extended, because otherwise the handle would not clear the inlet. More #40 holes were drilled along the side in the deck and then the area was filed smooth. The inlet had a slit cut out for the handle.
