Brief Description: More Wire Wrapping/Safetying/Tanis Plug
The #1 and #3 EGT/CHT wires were clamped to the engine mount along with the Amps Lo and Hi and the alternator wires.
The safety wire from the oil temp sensor to the mechanical tach cap was redone and made tighter. The sensor wire was reattached to the oil temp sensor.
The Tanis plug mount bracket was clamped in place on the oil dipstick. Vinyl tubing was wrapped around the dipstick under the clamps. Additional tubing was placed under the upper tubing to push the bracket farther away from the dipstick. A tiewrap was placed at the lower end of the bracket to wrap around the wiring. The plug was inserted and another clamp was tightened around the bracket and the plug.
The wires clamped
The oil temp sensor safetied and the wire reattached to the sensor
