Brief Description: Used Adel Clamp Keeper Tool to Install Clamp
I had purchased an Adel clamp keeper tool from Aircraft Spruce and used it for the first time to help install clamps. The two clamps were pressed together and the the keeper tool was inserted onto the threads of the bolt. The tool held the two clamps together and a washer and a nut were then threaded onto the bolt. The tool was pulled off with no problem. The tool works pretty well!
