Brief Description: Finished Making Firewall Pass-Thru-Ignition Wire
The fireseal to be wrapped around the ignition wires had to be trimmed, so about three inches was cut off. After the fireseal was wrapped around the wires, Teflon tape was wrapped around the fireseal. The fireseal was then pushed into the pass-thru from the firewall side until it reached the firewall. The fireseal cylinder was then pushed onto the fireseal and the clamps were tightened. One pass-thru is complete!
The Lightspeed ignition wires wrapped in the firewall pass-through
