Brief Description: Replaced P1 Wire/Attached It to ALT CB
The P1 wire was replaced in its original position, screwed to the Master Relay and run thru the hole in the firewall. A terminal nipple was placed over it and the Master Relay bolt and nut. The wire was run up the tubing inside the firewall and then under the right instrument rib. A hole in the instrument subpanel was drilled and one bushing was fit inside of a larger bushing and then into the subpanel. The wire end then had a terminal crimped onto it using the Swedge-On Tool, with heat-shrink applied. The terminal was screwed onto the Bat side of the Alternator CB. The two holes in the subpanel were labeled ALT and BAT for the wires coming thru.
The ALT and BAT wires from the firewall to the alternator CB
