Brief Description: Attached Oil Cooler Shutter Door Cable
A hole was drilled in the left rear baffle for the magneto cooling tube.
After riveting the aft left baffles together, they were reinserted in place on the engine.The cable was inserted into the nut on the shutter. The lever on the shutter was too wide for the attaching nut and had to be narrowed using the die grinder.
The oil cooler shutter door
The cable on the nut
The two baffle pieces riveted together with the spacer in place
