Brief Description: Attached Oil Hose to Fitting by Engine Mount
The oil pressure hose was screwed to the fitting under the engine mount. This connection results in the hose and fitting coming very close to the engine mount. My concern is that the vibration of the engine could cause the fitting to come into contact with the engine mount and possibly crack the fitting.
This situation requires further investigation.
The oil pressure hose and fitting by the engine mount
