Brief Description: Brake Hoses/Elastic Grommet-Wires/Oil Door Cable
I wrapped a tie-wrap around the two brake hoses that go to the firewall. I ran the tie-wrap thru a plastic hose to keep the hoses separated.
The EGT, CHT, oil temp and fuel pressure wires were run thru the rudder pedal support and I split an elastic grommet and inserted it in the hole to better support the wires.
The cable for the oil cooler shutter door was run thru the firewall pass-through eyeball and the eyeball was tightened.
