Brief Description: Routed Sparkplug Wires into Plugs
I separated the sparkplug wires from the EGT and CHT wires that had been clamped together on the right side. The EGT and CHT wires should not be run next to the high power sparkplug wires. I tied the #1 and #3 sparkplug wires together coming out the magneto and clamped them onto cylinder #3. The bottom four dehydrator plugs were removed and the sparkplugs were screwed in place, but not permanently. The plug wires were run on each side and clamped onto the cylinders, then screwed into the plugs to check the length of available wire. Two brackets were made for bolting two clamps together onto the engine mount on each side. These clamps then had the plug wires installed and the bolts installed with AN363 nuts.
