The bracket will be riveted to the left side of the firewall and the transducer will be fit into the fuel system between the engine-driven fuel pump and the carburetor. I need to get the proper length of bolts for attaching the transducer to the bracket.
The manifold pressure line was disconnected to the firewall so that the flow transducer bracket could be worked on. The bracket was drilled to the firewall and two holes were drilled thru the cross-angle riveted to the inside of the firewall. The bracket was riveted to the firewall with AN426-4 rivets. Straight fittings were screwed in place on the transducer.
The fuel flow transducer sitting on the bracket on the firewall
