Baker's RV-6
Date:  6-3-2011
Number of Hours:  0.50
Brief Description:  Installed Crush Washer on Oil Temp Sensor
I received the Aircraft Spruce order, which included the AN900-10 crush washers. Per many VAF posts re the oil temperature sensor, the crush washers are used on the sensor. I placed a washer under the sensor and tightened the sensor. The washer did not stay centered on the sensor and was split off to one side.
Update--This washer was replaced 6/6/11.
