Brief Description: Installed Firewall Pass-Through on Left Side
The firewall was drilled for another pass-through on the left side. The LSE ignition cables and the input cable from the Hall sensor will be run thru it. The 1 1/8" hole cutter was used to drill the hole after a pilot hole was drilled. The hole's edges were cleaned up with the die grinder. The doubler was clamped in place to drill the screw holes with a #19 bit. After the holes were deburred, the pass-through was screwed into place.
