I used .032" safety wire to safety wire the oil quick drain plug. I reviewed the wiring for the manifold pressure. One of the three available ground wires needs to be plugged into the manifold pressure sensor with two other wires. The ground wire, #17, is specifed for the sensor. I will need to unplug the EMS wiring harness and checking the continuity of the three grounds to determine which ground is from which plug in the harness.
I ran the oil pressure wire thru the pass-thru and crimped a ring terminal to its end. The terminal was then screwed onto the oil pressure transducer.
