Brief Description: Photos-EGT/CHT Wires Plugged and Working!
I crimped the Fast-on terminals to each of the eight wires for the EGT and CHT indicators. The wires were run to the appropriate cylinder and plugged into the female Fast-on receptacle. The power supply was plugged into the panel and turned on. Each of the EGT and CHT indications indicated a temperature of 66-69 degrees F, which was the temperature in the shop! Another item checked off!
The EGT and CHT wires connected
The temperature indications show in red, bottom left side-66-69 degrees F
