Brief Description: Cut Angle Brackets for Oil Cooler Mini-Plenum
Many RV pilots have reported cracking around the oil cooler installation when it is installed on the aft baffle behind the #4 cylinder. I found that Randy Lervold, RV-3B builder, made a mini-plenum to offset his oil cooler from the baffle. I decided to copy his copied design.
Drew worked with Dan Kurtz to cut lengths of .062 x 3/4 x 3/4" angle to make the mini-plenum. They cleaned up the edges on the Scotchbrite wheel. Drew drilled the vertical sides to each other with the #30 bit.
