Brief Description: Assisted Gary with Throttle and Carb Heat Cables
John McCreight assisted me with riveting the cowl inlet ramps, drilling the firewall for the throttle steel passthrough and installing the throttle and carb heat cables.
Close-up of the throttle, carb heat and mixture cables coming thru the firewall
The control cables on the instrument panel bracket
