Brief Description: Cabin Heat Control/Mixture Cable Hole in Firewall
I measured the position of the mixture cable so that the firewall grommet could be used, which requires a 1 1/8" hole. The hose that connected the left and right exhaust pipes was removed for better access to the firewall for drilling and installing the grommet. A pilot hole was drilled in the firewall.
