Brief Description: Moved Fuel Line/Removed Control Cable Bracket
I rotated the fuel line fitting into the carburetor upward, as well as the fitting from the fuel pump. The fuel line was lifted a little bit more away from the exhaust.
I removed the cabin heat cable from the vent box arm and the three Adel clamps that the cable went thru. I then took the five-hole control cable bracket off the instrument panel. I used a Unibit to enlarge the four holes in the new control cable bracket for the cables.
The fuel line moved a bit farther away from the exhaust
