Brief Description: Trimmed Sides of Windshield/Drilled to Roll Bar
I called Scott-Van's re the notching of the top skin for the windshield. Scott said it was an option to do.
I decided to trim 1/2'' off each side of the windshield. This will allow the windshield to lie more flat against the top skin, if I don't notch it. If I decide to notch the skin, the notch will be that much shorter. I used the oscillating tool to trim the windshield and then used the mouser sander to sand the edges.
I added a few more clips along the front of the windshield. I drilled the windshield to the roll bar, starting in the top center, working down alternating from side to side. The canopy was closed so that I could match the arc of the windshield to the canopy. As I drilled down each side, I added nylon washers between the roll bar and the windshield. I added one to three washers along the bends to have the windshield align with the canopy.
The left side of the windshield trimmed
The right side of the windshield prior to trimming
The left side clamped in place before drilling to the roll bar
