I installed four K1000-4 nutplates for smoke system. I drilled new holes in the aft smoke system bracket. I pop-riveted the baggage floor back into place. I received my Aircraft Sruce order of Adel clamps and installed two clamps for the right side blue tubing. I made a bracket for the static tube T-connector and riveted it to the F-606 bulkhead. The T-connector was then screwed in place. I used AN-4 bolts to attach the smoke reservoir to the floor in its new orientation.
The baggage floor reriveted after installing 1/4" nutplates
