Brief Description: Tested Battery/Worked on F-6106 Top Skin
Tested the Odyssey battery. The voltage showed at 12.67 volts. I taped a steel tube in place on the sides of the F-6106 top skin and attempted to roll the skin so that it would fit better over the fuselage. I worked on one end of the 1/8" bracket that will be riveted to the center F-6108 rib. The end will be riveted to the bracket on the firewall. I didn't cut the end properly, so I cut it off and reworked it.
The steel tube taped to the edge of the F-6106 skin
The end of the angle bracket that I cut off and reworked
