Brief Description: Worked on Forward Top Skin and Ribs
I drilled the F-6109 bracket to the center rib, F-6108. I marked the area already cut out of the rib onto the F-6109 and cut that area out. Cleaned up the cut marks on the Scotchbrite wheel. I marked the glareshield cutout on the F-6106 skin and used the bandsaw to cut out that area. I started to clean up the cut marks with a file and the die grinder.
F-6109 doubler bracket in position
Doubler bracket modified for lower cutout
Forward top skin with the initial cutout for the glareshield
