Brief Description: Installed Fuel Line into Pump/Doubler on Rib
I decided to not use the fitting on the intake side of the fuel pump, because I did not it. I was able to make the 90 degree bend in the fuel line into the pump. I installed the fitting and flared the tube end. I cleaned up the F-6109 doubler that will be riveted to the right side of the instrument panel center rib. I marked the bottom front end that will need to be trimmed off.
Fuel line into the pump
F-6109 doubler on the instrument panel center rib
The front bottom of the doubler that will need to be trimmed
