Brief Description: Positioned Fuel Pump on Firewall/Static Line
I rearranged some of the storage bins of hardware. I positioned the fuel pump in place on the firewall. I need to order some hardware for fastening it. I drilled two 1/4" holes in the left side of the F-604 bulkhead for the static line, then I ran the static line thru the holes.
Fuel pump and doubler drilled in place on the firewall
