I attached the rudder cables to the pedals. The fork ends of the cables do not line up properly coming out of the bulkhead bushings and are rubbing. I rearranged the order of the washers to move the fork ends to a better position. It's not enough, so I'm going to order some longer clevis bolts to correct that problem. I bent 3/8'' tubing for the left wing fuel line. Got the general shape made up. The tube bender scratched the tubing, so I'm not sure if I am going to use that tube.
Riveted a nutplate in place on the center rib for the instrument panel.
Nutplate on instrument panel center rib
Left rudder cable positioned with washers on the inside
