I painted a few interior pieces that needed a touch-up. I torqued the flap actuator bolts. I changed the AN960-10 washers to -10L washers first to get the proper thread clearance. I torqued the rudder pedal bolts, but first had to add a second washer on each bolt. I reinstalled the fuel vent tubing on both sides.
I sent in my order for the O-360 plenum from Sam James-James Aircraft. I have talked with Will James, who makes the cowlings. I am on Will's list. He will call me when my cowling is about thirty days away from being completed.
