Brief Description: Drilled Brake Reservoir Hole in FW/Primed Top Skin
I made an angled brace to attach the front of the bracket to the cross rib and clamped it in place. Drilled access hole in the firewall for the brake reservoir fitting. Cleaned up the top skin with enamel cleaner and then primed it.
